crankshaft
wdp
Can I use a 67 crank in a 71 block without having clearance problems? Just had the 67 crank turned and found that the block was bad. If I can reuse this crank I can afford a cross flow head. OK, afford part of a cross flow head!
Yep on using the crankshaft.
