TR2/3/3A crankshaft shims to align timing sprovkets
Dr_Mike
having finally got the woodruff keys ou, replaced crankshaft fixed end-float, etc. I added what seemed to be the right thickness of shims (.014 ) to align the two sprockets. I was disappointed to find the, with the shaft pushed forward against the front washer that there was still. 006 to go. With .004 end float just hoe closely
do the sprockets have to align?
TR3driver
Great Pumpkin - R.I.P
The cam also has some end float, so IMO you need to check the sprocket alignment with both of them pushed either all the way forward or all the way back.
Since the shims come in .002" steps, I assume .002" is the alignment tolerance. If they could have just used .004" shims, then why bother making the .006" ones? But that's just a WAG.
Dr_Mike
thank you. Not sure what a WAG is ( Wild A Guess?) I managed to lose some sleep over this and came to a similar conclusion. There obviously is some allowance for play and I shall try to set the sprockets in the middle of this.
Thank you again
TR3driver
Bingo.
There's also SWAG (Sophisticated WAG), but it's pretty much the same thing :smile:
CJD
The crank will tend to move forward when the clutch is engaged and float at other times. The cam, however, should ride fully rearward, since the lobes are ground with a slight taper to cause that to happen. So, I set the clearance with the cam rearward, and then average the crank float. But that's just me.
B MGB Mgb crankshaft end play shims MG 2
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 7
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
Gerard 1098 10CC crankshaft Spridgets 14
vette Timing Cover crankshaft pulley seal Austin Healey 6
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
M Healey Crankshaft Thrust Washer Thickness Austin Healey 3
Tugboat Crankshaft Pulley Question Triumph 4
