Early '74 MGB. Need to remove crankshaft pulley bolt to remove pulley to remove timing cover to replace oil seal that leaks.
Radiator is out, belt removed, steering rack loosened and forward, , tab bent flat, and I have a very big socket set just right for removing the bolt. Now, how do you do that without simply turning the engine over? I've looked for older helpful posts but the idea of "tapping it with the starter" gives me the creeps.
I have enough leverage for the bolt that I shouldn't need an impact wrench.
Would appreciate some good ideas.
Thanks.
Thanks.
