TR2/3/3A Crankshaft Oil Galley Plugs
mastaphixa
Bronze
I'm preparing a Tr3 crankshaft for delivery to the machine shop for evaluation and inspection. I want to remove the oil galley plugs from the crank, and I know I have seen that mentioned in threads before but I'll be darned if I can find them now. Am I off base just taking the crank to the machine shop and asking them to accomplish whatever work is required, remove the plugs and provide me with new plugs, so I can make sure everything is squeaky clean before the plugs are reinstalled?
TR4nut
That’s what my machinist did for me - in fact he refused to do the work unless he pulled the plugs to make sure everything was clean. He did not reinstall the plugs but it was pretty easy to find suitable ones at McMaster Carr.
CJD
Are you talking about the aluminum plugs at the ends? The shop can easily remove them for you, and chase the threads for you. I doubt they will have the replacement plugs, so you would have to supply those. They are now a “specialty” item as the world has left us behind another year today!
M
mastaphixa
Bronze
Actually I was talking about the plugs in the crank throws (I was unaware there were plugs in the ends.) I suppose re-balancing is called for after installation of the replacement plugs.
TR4nut
It’s a good idea I think to balance everything regardless. Not a lot of money and gives you a smooth running engine.
M
mastaphixa
Bronze
I have successfully removed the soft aluminum galley plugs from my crankshaft. A friend of mine machined three drill bushings that really helped with the process. I ran across a video showing a machinist removing the "sludge plugs" from a crankshaft that looks an awful lot like the plugs in our crank shaft:
https://www.youtube.com/watch?v=pKstqVicgZA
I will make a second reply to this thread to include some more pictures and a copy of the drawing I made to develop the drill bushings.
Steve Baker
M
mastaphixa
Bronze
No matter what I do, when uploading images, they are not placed in the order that I want, so the basic process goes like this. I used a counter sink to provide a basic center for the #16 (.177") drill in the first bushing. Drilled that hole, and used the second bushing to step the hole up to 3/8" and the third bushing up to 7/16" That left a thin layer of aluminum I could scour away using a small crimped end wire brush inserted into the plug bore. After almost all the aluminum m was removed, a scribe was used to pick the remaining aluminum out of the threads, followed by a 1/4" tapered pipe thread tap to clean things up. A new steel or aluminum plug can now be threaded in to the existing threads after the machine shop is done with the dirty work and before balancing. I include a drawing I used to develop the drill bushings.
W Crankshaft Oil Seal Austin Healey 3
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
J How bad do Spridgets leak oil from the crankshaft? Spridgets 18
vette Crankshaft Rear Oil Seal Austin Healey 11
M Crankshaft Oil Conversion Kit Spridgets 6
R6MGS T-Series MGTC Front Crankshaft Oil Seal MG 5
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 6
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
GTP1960 TR2/3/3A Moss Crankshaft pulley failure Triumph 23
C Tough Bolt on front of Crankshaft Spridgets 16
TRMark TR4/4A Prepping Crankshaft Triumph 4
D TR2/3/3A crankshaft shims to align timing sprovkets Triumph 4
KVH General Tech Crankshaft Main Bearing and Oversize Puzzle Triumph 5
tinman58 TR5/TR250 Front crankshaft seal Triumph 0
2billydavies TR2/3/3A removing con rod from crankshaft Triumph 4
J TR2/3/3A Crankshaft thrust washers. Triumph 2
C Crankshaft pulley / damper Austin Healey 5
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
M For 1974 MG Midget - Crankshaft pulley bolt is 1 5/16"? Spridgets 4
M Spitfire need a crankshaft pulley for 1978 Spitfire Triumph 0
M_Pied_Lourd TR2/3/3A TR3A Crankshaft Question Triumph 3
B crankshaft/cam timing Austin Healey 10
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
