Randy Forbes said:If you're doing it while the engine is inside the car, well, good luck! Put the trans in reverse (highest multiplication) and set the handbrake. You may still need someone to STAND on the brake pedal to keep the engine from turning.
Hi Randy,
I have the luck of installing it with the engine in the car
Are you wishing me luck for getting the damper onto the crankshaft or tightening the nut :confuse:
I put mine in the oven, 200 degrees. I was able to handle it well enough wearing welding gloves (the really thick ones that make you wonder if you still have fingers, as you sure can't feel anything).GregW said:One other thing to remember about the Pro Race damper. Soak it in hot water for 15 minutes (I think) to allow it to expand. Goes on much easier that way.
I don't see a depression to set the locktab washer into on the dampener, so it would be prudent to use some thread locker. I'd recommend the Loctite "blue" so that it could be disassembled without needing to be heated.higgins said:The Pro racer arrived today; good looking stuff.
One last question, though. Should I use the standard lockwasher for the Crankshaftnut or is there a special recommendation from your side?
regards
Higgins
Isn't the 100 engine "dampenerless"? If that's the case, then adding one probably won't make much difference.zblu said:Looked into these, and was basically told off the record for a 100/4 they wont do much unless you are pulling a lot of revs
Randy,Randy Forbes said:Isn't the 100 engine "dampenerless"? If that's the case, then adding one probably won't make much difference.zblu said:Looked into these, and was basically told off the record for a 100/4 they wont do much unless you are pulling a lot of revs
In the case of the sixes, a dampener was originally fitted, but by now, most have already delaminated or aren't trustworthy to use. I know of one failure firsthand (Layne Perkins BJ8) that when the dampener came apart, it broke the crankshaft at the 1st main journal. That was fully 20 years ago, and those rubber fillers have not gotten any younger.
Really, it's more a case of cheap insurance than a performance upgrade.
I was given a source for a rebuilder and was thinking of going that way. I think new ones(performance brand?) are about $400 and to rebuild is less than half with shipping.zblu said:If it wasnt for the weight/cost I'd probably put one on for the incremental improvement, but in your case Patrick67BJ8 I'd replace as you say its a few decades old now and probably gone hard
