I got the crankshaft back from the machine shop Friday and installed it in the block with much better results this time. I did not turn the mains last time because they were still in spec for ten under. When I installed them with the new 010" under main bearings they were measuring 004". The ideal measurement should be 001"-0025". This time I had the mains turned 020" under and after installation they measured 0015". Much better than the 004". The rods were also checked and they were fine.
