Tabcon
When I first installed my crankshaft a month or so ago, the end play was around .010", so I ordered some larger thrust washers that are oversized by .005". This should have translated into an end play of .005". However, after I installed the crank today, it was so tight I couldn't turn it by hand but only with a wrench attached to the crank/fan bolt. The second I loosened the cap holding the thrust washers, I could easily turn it by hand.
The new thrust washers I'm using, as well as all the main and rod bearings were coated by Calico Coatings. I'm thinking the coating may be making the thrust washers a bit too thick and making the crank difficult to turn. I also had my oil pump and the internals coated with the same material. It too wouldn't spin very easily at first, so I greased it up a little and attached a drill to the end of the pump shaft. It loosened up nicely and works fine now.
I have a set of new (non-coated) standard sized thrust washers also. Would it be alright to mix and match the 2 different sized washers, i.e the standard size on one side of the journal and the oversized coated washers on the other, or would it be best just to try and remove some material from the oversized washers?
