According to some research I did previously, a GT6 (rubber) damper is a direct fit. However, along with a fairly recent thread, the determination was that the 1500 had a resonance above the normal frequencies of operation (perhaps 5500 RPM or higher). While I feel that a fluid damper would be most desireable, they are expensive and I would have to figure out a way to make it fit. Lightening the rotating mass is the next best way to increase the resonance, and it's generally less expensive (alloy flywheel: $400). Lightened pistons, rods, and crank can also help, but that starts to add up. The easiest way is by lightening the flywheel.
