I isolated the noise that I thought was a water pump by removing the belt on my TR4. It has an electric fan conversion with long neck aluminum radiator. I discovered the crank bolt was finger tight! I took it off and the pulley came off feely. The 1/2 moon woodruff key was in place. But the key way in the pulley is worn giving it side to side movement. I need to replace but don’t know where this conversion would come from? Here is a picture. Any help very much appreciated. Good news crank end is fine. And when I started it to check for noise, wonderful quiet. Just the gentle exhaust rumble and gentle valve train. Thanks again. Charlie
Hi Guest!
