Crank damper alignment
RestoreThemAll
I installed a crank dampener rebuilt by damperdudes on my BJ7 following the great advice from the BCF about heating to 275 degrees, adding little light oil on the crank and tapping it on. It did go on nicely. Yes, I wacked it a couple of times for the final seat.
I don't believe it's right though. It looks like it should go another 3/16" to 1/8" or so. For one thing the pulleys don't line up.
In the pic labeled "dampener all the way home" it looks like it should go on farther. Should the dampener be flush with the shaft shoulder in that pic?
In the pic "threads left on dog nut" it looks like the nut could go on further. Should it?
I measured the crank snout from the end to the oil slinger 1 1/8" and compared that to the depth of the dampener 1 5/16". The dampener is pressed on to the slinger. The timing gears line up perfectly. I must be missing something.
In the pic "dog nut lock washer" the lock washer is shown. It's not the same as the tab washer that came off. The washer came from AHspares. Here's a pic from the AH Spares web site. Is it just a different style lock washer?
https://www.ahspares.co.uk/austin-h...G595-to-ENG680/LOCKWASHER-crankshaft-nut.aspx
Lastly, my bently manual doesn't show a torque spec for a dog nut. Does anyone have that?
Thanks in advance for your thoughts.
re: "... For one thing the pulleys don't line up."
All the evidence you need that something ain't right. It looks like you have the oil slinger outside of the seal; it should be inside. As far as a torque spec for the dog nut; I've always torqued as tight as I can (it's not likely you'll break the crank).
R
RestoreThemAll
Bob,
I see what you're saying about the oil slinger and thought that at first. When I was laying out the parts in preparation of install I noticed that the lock washer is concaved similar to the oil slinger. So I looked it up on the AH Spares web site. One nice thing about that site is they provide great diagrams and pictures. The part that I have is clearly labeled lock washer. It matches up with the picture on their site. There is an oil slinger between the seal and the gear that's in place where it belongs. The oil slinger is a bit larger than the lock washer.
The pulleys are misaligned by an 1/8" give or take a little. I don't like it but I can't see a reason why.
The crank is in place. Can't mess that up, right?
Then shims to align the gear to the cam gear.
The gear next.
Oil thrower after the gear.
Timing cover with seal aligned to center the dampener.
Finally the dampener install.
The rest is described above.
Seems simple enough.
I'm concerned about the belt alignment but more so the dampener itself. I've read the experts on this forum who have warned about improper installation of the dampener. It's a critical component.
I'm still scratching my head about this one. I can't wait to get on to the body work. I'm much better at that stuff.
R
RestoreThemAll
Update: Ron from Damperdudes was very helpful in sorting some of this out.
There are 9/16" of threads on the crank shaft available for the crank nut to capture. There are 13/16" of threads in the nut. If the washer is considered then 1/2" of threads secure the dampener. That should be OK, right?
The two pulleys, water pump to dampener, are misaligned by about 1/8" inch.
Pump: from the front engine plate to the center of pulley is 2”
Dampener: front engine plate to center of pulley 2 & 1/8”
Comparing the old pump to the new one
The old pump pulley measures 2 & 7/16” from the edge of pump body to the center of the pulley, new one 2 & ¼”.
So the new one does set back farther.
Is it possible that the pulley on the new water pump is pressed on too far?
Dale
R
RestoreThemAll
Update: I've been working with AHSpares on the pulley alignment issue. Those guys are really great to work with. Very helpful. I replaced the water pump with a new one from AHSpares. The manufacturer pressed the pulley on the water pump about 1/8" too far. They're sending me a new one at their expense. The one I have now is junk, as the pulley can't be realigned without losing the friction fit.
My concurs manual says that the distance from the block to the edge of the pulley is about 2". AHSpares took several measurements from at least three different water pumps. They're all 2". Go measure your water pumps. Are you wearing out belts?
There were a few things going on, as explained above. I'm very pleased with the support from both vendors. Excellent service!
The last of this for me is the lock washer and torque spec. I'm going to clean up and use the original. That new concaved lock washer just doesn't seem right. I'm using a 3/4 drive socket ratchet. Without a spec I'll make it tight without striping threads???
Dale
BoyRacer
Tighten it up to about 90-95 ft lbs and you'll be fine. The bad harmonics only come into play around 5900 RPM. That's when the damper can come loose and fret the crankshaft if not snugged up properly. We racers usually torque it to as much as 120-130 ft lbs and that's with an interference fit- high performance damper such as an ATI Superdamper. But that's because we rev our motors to as much as 7000 RPM.
Bob Hughes
I put a super damper on when I rebuilt my engine and my Healey guru says 120-130ft lbs and I was obviously not going to race mine.
:cheers:
Bob
T Replacing the crank pulley/damper Austin Healey 4
wangdango ProRace crank damper? Austin Healey 6
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 13
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
J 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
Drone Dog BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
R TR2/3/3A One more crank pulley question Triumph 7
R TR2/3/3A Crank pulley question Triumph 4
GTP1960 TR2/3/3A Timing cover/crank hub oil seal Question Triumph 4
Boggsy64 MGB Crank doesnt turn freely - new main brgs MG 21
jfarris TR2/3/3A TR3 tining without marks on crank pully Triumph 6
T TR4/4A How to determine if the crank is good before pulling the engine out Triumph 8
R timing gear crank shims Austin Healey 11
R Dennis Welch Rear Crank seal conversion - Gap in back plate Austin Healey 19
R Engine crank shaft nuts Austin Healey 1
B Remove Crank Nut Austin Healey 55
M_Pied_Lourd TR2/3/3A Crank Oil Slinger Orientation Triumph 2
S TR4/4A Water pump and crank nose questions Triumph 7
GTP1960 TR2/3/3A Removing the fan extension from the Crank hub Triumph 13
T TR2/3/3A How many guide holes in TR3 flywheel for crank pin? Triumph 2
M Crank Pulley Removal Austin Healey 12
J General TR Narrow Belt crank pulley Triumph 0
T TR4/4A Oil drain hole from rear crank seal/rear main cap Triumph 3
K TR2/3/3A Su carb rod linkage bell crank stud? Triumph 6
CJD TR2/3/3A Crank balancing Triumph 11
B Chip off the crank pulley Austin Healey 12
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
jaegzie Size on head on end of crank Spridgets 1
Scotsman TR2/3/3A Crank Pulley Triumph 2
Geo Hahn TR4/4A Crank Bolt Size Triumph 5
