British Car Specialists on the West Coast and Healey Surgeons on the east coast can do this. You remove the shaft and pedestals and rocker arms and send them in. They replace the shaft and re-bush the pedestals and ream the rocker arms (I think--I had mine done 30 years ago, hard to remember the details, but it is a common Healey repair. You reinstall taking care to reassemble the oil banjo fitting carefully. A worn shaft will have deep grooves on the bottom of the shaft where the rocker arms pivot. Oil will shoot up in this case instead of dribbling out of the top of the rocker arms when the engine is running (idling).
