Installed Crane XR700 and cannot get the the engine to fire.
Verified by the #1 plug not showing a spark at the plug.
12VDC is at the coil. Ground confirmed. 6 cyl rotating ring is pushed down all the way, clearance between the optical sensor and the rotating ring is ok.
I am not sure if the optical sensor is correctly posiitoned.
I it is possible to look at this pic and see if it looks correct would help. #1 cyl was at TDC. Rotor is in correct position but is the optical snesor correct as this is as far as it can be moved.
The instructions are not clear if the optical sensor has to be lined up with the center of the rotor at TDC.
I used the Condensor mount hole to mount the arm which mounts the sensor bracket. Another pic of a known working circuit may help.
Thanks.
Arlie
Hi Guest!
