Hello to everyone, I'm not a Sumbeam person, but a friend races an Alpine in vintage events. He was in the process of rebuilding his engine when he discovered a crack on his block about six inches long towards the base of the water jacket where it flares out. The crack appears to pass through a threaded hole I'm guessing for a drain plug. He then decided to try another 1600 block off a parts car and found a similar crack. Was this just bad luck or is it a common problem and does it lead to bigger problems later? Thanks.
