Just wondering - does your doctor give you advice on using the machine, and on how to get used to it?
Or do you just take it out of the box and try to figure out how to adjust it?
TM
The technician at the sleep center did a very good job of instructing. But the great thing about the current machines is that they are automatic and "ramp up" as needed, depending on the parameters set based on the sleep study results. After the first week or two, the patient usually returns to the sleep center for followup. Which is easy, as the machine reports via cell "phone" to the center with readings it gathers each night. Pretty neat.
I was also given a two-week period to try out the mask; if it wasn't comfortable, I could change it out at no charge. As others have said, if you've not used one before it does take a while to adjust.
Oh, and all supplies are on a schedule for automatic restocking.
Yes, I'm on Medicare.
Hi Guest!
