My fuel tank is clean, I have a silver in line filter and a Powermax in line fuel pump which is sited under the back seat, which leads up to two inline filters just in front of the carburettors
The car starts and runs great but after driving for a while it starts coughing and spluttering and backfiring, so much so I have to pull over
When I lift the bonnet and look at the transparent filter just in front of the carb it is only half full of fuel
I switch off, wait a moment and switch the ignition on and the bowl fills to the top, then the car will start and run great again for half a mile
My diagnosis is the silver in line filter is clogged and the fuel pump is low not high pressure
I intend fitting a correct SU high pressure pump........unless anyone knows different?
Ta
Ta
