TR2/3/3A Correct trafficator control head?
John_Progess
The trafficator that came in my 60 TR 3A with an adjustable steering column does not have the chrome ring around the horn button so I set out to install one from some spare parts. When I took the control head out of the steering wheel I noticed that it is slightly different from my spare parts trafficator control head. The stub on the control head that slides into the main stator tube in my column is 6.5" long whereas the stub on my spare control head which has the chrome ring in the center is only about 2" long. Where there different trafficators made for these cars? Can I use the control head with the shorter stub? My main stator tube is 61.5" long. If I use the control head with the short stub and my existing main stator tube the unit will be 4.5" shorter. Will it be long enough to go thru the steering box? The car was disassembled when I got it so I don't know what the steering column looked like when it was installed. It is the split column. Thanks again for your help and have a good day!
John
CJD
I ran into this last year. The short tube is for the non-adjustable trafficator. The longer is for the adjustable. The tube assembly can be removed and swapped for your longer tube by simple removing 3 screws. Otherwise they are identical parts.
TR3driver
Great Pumpkin - R.I.P
What he said. But the stub & stator tube need to match; and the adjustable wheel needs the long stub/short tube (unless you never adjust the wheel).
Kleykamp
What they said. I think, though, if one head is better than the other, you can just take the chrome ring out and put it in the better head. disassemble carefully, there are springs in the turn signal mechanism. Not a fun thing to have to remove over again to get the little parts in the right order and direction. Any I have seen with the chrome ring missing, was just that...the chrome ring missing.
CJD
I did notice when disassembling mine that there are slight differences internally. So, some parts are completely interchangeable, like the locator tube, but some parts are not, like the cancelling cams. I do not know if the differences are early to late, or OEM to Repo. I just know there are some differences.
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
BN6_2197 Correct adjustment of front axle of BN6 Austin Healey 14
S T-Series which way is correct MG 6
K TR2/3/3A Correct position for flasher bracket? Triumph 7
T GT6 These sills have been replaced, correct? Triumph 7
R Correct Brake Caliper colour Austin Healey 9
bighealeysource Source for correct washer for overdrive drain plug Austin Healey 6
C Correct mounting of exhaust on my 100-6? Austin Healey 9
Got_All_4 TR2/3/3A Throttle shaft assemble does this look correct Triumph 5
Rut TR4/4A Correct grill? Triumph 6
F MGB Correct steering wheel - 1974 MG 2
C Correct color of carb heat shield, starter, and generator? Austin Healey 12
R Cam gear nut correct torque Austin Healey 2
