correct rear axle oil
robert_ellison
What is the correct rear axle oil for a BJ-7?
For the transmission.ovedrive it was recommended to use 30wt non-detergent oil and stp mixed. Would that be functional for the rear axle, or redline (which many people felt was too thin & caused leaks)
robert_ellison said:
What is the correct rear axle oil for <span style="font-size: 9pt"> </span> a BJ-7?
:savewave:
The BJ7 utilizes a Hypo id rear Axel. Consequently it can be serviced using a Hypo id oil. A popular weight is 90/140.
For the transmission.overdrive it is OK t
o use 30wt non-detergent oil. However, in some cases wear in the OD may dictate a higher viscosity oil be used.
On the other hand, STP should not be used for the tranny, it can cause excessive slipping in the OD.
Many people felt Red line was too thin & caused leaks)
-------------------------------- :cheers:----Keoke
/quote]
