sockeyedsushi
73 Midget 1275 - R&R'd the dash, everything working, but the gas guage. I took the tank down and found the sender cover had fallen off onto the arm and was blocking the arm. I reassembled it and tested it. 0-199 ohms. e/f. Re-installed the sender in a front to back configuration but the guage only reads 3/4 when full. Question. Is this the right sender for the guage/car? Is it broken? Wrong configuration/orientation to the tank? Does the guage need adjusting? Any ideas would be most helpful. /ubbthreads/images/graemlins/cryin.gif
Hi Guest!
