Correct color of carb heat shield, starter, and generator?
christophe
Everything on the 61 Healey is painted healey green. What color should the starter, generator, and carb heat shield be?
Thanks
Gearhead_Garage
The same colour. Even some of the rubber hoses were painted green.
I have always thought the appearance of the Healey engine bay with the acres of that goofy green paint was a disappointment when compared to the svelte curves of the body. All the Healey contemporaries had much nicer looking engines and I always thought it was the Healey's only real fault.
While I respect a nicely detailed original engine bay, I didn't want to look at one.
attachment.php
Healey Nut
I really don't understand this whole " has to be correct" thing . Its your car do what you like . I don't do concourse and never will I add personal touches to my cars . Small subtle things . Always stainless steel on exposed fastners in the engine bay . Polish up and clear coat the copper piping . Polish the dashpots etc etc . Again its your car do what you want . I much prefer to look at cars where owners have strayed from the concourse look and added personal touches , it personalizes the car and shows what can be done with a little more thought and time .
andrea
Here some good photos
https://picasaweb.google.com/112770819864514987162/DropBox?noredirect=1#5455601709579770818
Engines arrived to AH plant pre assembled and tested --and (probably) paint with olive green normally applied by Austin to the standard units- less carbs and intake and exhaust collectors that will be applied after the repaint at the AH plant- where units was painted as normally used on marine engine- with no insulation and included the generator and the starter il light metallic green
I agree with Derek also the belts are originally painted LMG in this process
This system can be confirmed by some engines find with the original olive green paint -probably put in the line
for insufficient re-paited unit issues-friday cars??
andrewss
Its your car so you do what you want with it... there will always be some smart arse that will find something to criticise even if you try and be Healey correct..
C
christophe
The car doesn't retain its original drivetrain anyway, so I am not super concerned about it being factory correct. I was just curious to know what is and is not correct. Thanks for the tip on the copper pipe...i plan to polish it!
Gearhead_Garage
I used the polish and satin clearcoat on a lot of components. It gives them a sheen without looking shiny, They clean easily and they don't tarnish.
For copper or brass I use a wire brush or steel wool to get them clean, then metal polish to shine. Then I clean with Prep-All to remove the polish residue before clearcoating with Wurth clear wheel paint.
For steel parts like the air cleaners or throttle linkage, I use my wire wheel to shine them up as uniformly as possible. Then some metal polish if necessary. Then Prep-All and clearcoat.
For fasteners, I use the wire wheel but hit them with a shot of cadmium-look spray paint before a shot of clear.
The best trick is to bake them at about 200-250 degrees in a toaster oven for about 5 minutes after the clear coat. It really hardens the paint. I bought a cheap toaster oven for the shop after the wife complained.
Patrick67BJ8
Don't let your wife catch you using the dishwasher to clean your chrome wire wheels! Cascade complete works well with spot free rinse.(don't ask how I know this)
AUSMHLY
attachment.php
I agree.
attachment.php
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
Joe Schlosser correct Dash board color Austin Healey 6
Jim_Gruber Correct Paint Color AND Horler Book Spridgets 17
J TR4/4A Correct color for TR4 wiring harness Triumph 5
M Correct Engine Color Triumph 4
M Dunlop Brake Caliper correct color? MG 2
Brian_James Correct color for Bugeye disk wheels?? Spridgets 7
bighealeysource correct dash paint/color on BN1 Austin Healey 8
H Correct Color Carpet for Black/Red 100-6? Austin Healey 2
A Correct Color For BJ8 Radio Cover "3000" Badge ? Austin Healey 18
C TR6 Correct TR6 Wheel Paint Color Triumph 4
C Correct Color and Car Value Triumph 27
Johnny Correct Top Frame Color? Austin Healey 5
klutterbutt Correct Paint Color? MG 12
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
R TR2/3/3A Correct Thermostat? Triumph 7
simon1966 Correct horns for a 54 100 Austin Healey 5
B TR6 Title with correct VIN Triumph 8
BN6_2197 Question on correct oil temperature Austin Healey 15
G Correct spark plug ends - early BJ7 Austin Healey 1
