Well, after two years, my clutch master cylinder failed. I just finished rebuilding it. The old fluid in the cylinder reservoir was a dark grey - obviously not a good sign. I thought I used the correct fluid, but it must have been wrong considering the result. I plan on removing the rest of the fluid and bleeding the whole system tomorrow. Can someone tell me the correct fluid to use? Are all fluids with the same DOT value the same? Are the symptoms I stated truly a result of using the wrong fluid? Suggestions would greatly be appreciated.
Kevin
Kevin
