correct BJ8 jack
Hoghead
My research shows that the correct jack for a 67 BJ8 is a Shelley LJ225.
Is this correct?
What does the handle look like?
Is it a metal rod with a wooden cross shaft handle?
It's a metal rod about 18" long and (I think) about 7/16" diameter, with slightly chamfered ends. This Forum's moderator Reid Trummel had some repros made a few years ago. I think you could make a decent one with some rod and a grinder.
The jack number sounds right, but I'm not positive. There are two versions of the jack, the later/best one has some additional webbing to reinforce the hole where the handle goes. They come up on eBay once in a while, but usually go for $300-400.
Dave Richards Correct Jack for BJ8? Austin Healey 41
S BJ8 Air Cleaners - correct finish? Austin Healey 21
G Correct location of front turn signal on bj8 3000 Austin Healey 3
D BJ8 Front Seats Foam on Back Pan Correct Fitting Austin Healey 4
S Correct Octane for BJ8? Austin Healey 12
S Correct colour BJ8 Spark Plug Wires / HT Leads Austin Healey 7
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
H correct BJ8 seatbelt Austin Healey 13
Ed_K Correct SU Fuel pump for a BJ8 [ PSI specs] ? Austin Healey 9
F Correct fluid in BJ8 tranny Austin Healey 30
J Finding a correct 1964 BJ8 steering wheel Austin Healey 1
RAC68 Correct PCV for BJ8 Austin Healey 7
H 1966 BJ8 Lucas Voltage Regualtor ,Correct Part No Austin Healey 9
6 Correct BJ8 seat height? Austin Healey 7
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
A Correct Color For BJ8 Radio Cover "3000" Badge ? Austin Healey 18
SHG Correct Rearview Mirror for a 1964 BJ8 Austin Healey 6
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
G D would anybody be able to tell the correct way to static time a essex v6 I have tried and failed cheers garth TVR 14
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
W Correct Tie Rod Ends Spridgets 0
Healey Nut Cross Rod Correct Length Austin Healey 14
S TR2/3/3A problems getting the engine to run correct Triumph 21
B Which is the correct door knob for a 59 bugeye? Spridgets 3
S TR2/3/3A Correct Starter Triumph 4
steveg TR6 Spec needed for correct ride height Triumph 28
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
Paulus TR6 Bumper Bars - what is the correct terminology Triumph 3
red57 What is correct wire harness outer wrap Austin Healey 17
dklawson GT6 GT6 Mk1 Oil Filter - Correct Part Numbers Triumph 2
S TR2/3/3A correct spire nut Triumph 4
J TR2/3/3A TR3A Throttle shaft bushing retainer plates, Correct color? Triumph 2
K Correct side screen nut for early 58 BN4 Austin Healey 14
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
I Correct orientation of the fan blades. Austin Healey 13
G Wanted Triumph TR4 [63] Period correct radio Triumph Classifieds 2
K Correct key head shape. Austin Healey 1
Gliderman8 TR6 Correct LED flasher relay Triumph 6
K TR2/3/3A Correct oil level for differential? Triumph 5
Jim_Gruber What is the correct Radiator Cap for a 948 with a Downflow Radiator Spridgets 4
BN6_2197 Correct run of the Choke Cable of BN6 Austin Healey 7
jfarris TR2/3/3A Which speedo is correct for a 1956 TR3? Triumph 8
L GT6 correct finish Triumph 5
Jim_Gruber What is the correct tool for removing brake lines from a BE Master Cylinder Spridgets 10
B MGA Correct wheel paint? MG 2
Gerald_Gordon TR4/4A Inconspicuous or period-correct backup light for TR4 Triumph 8
simon1966 Correct Jack for a 54 100? Austin Healey 5
C Need to order correct size Austin Healey 4
Joe Schlosser correct Dash board color Austin Healey 6
