Jamie
Hi all. My Haynes doesn't outline the correct way to install oil pan gaskets and corks. I've replaced them but I still have leaks. I've read on another forum - "The curved gasket (or seal) should protrude about 1/4" ( 6-7 mm ) on each end of the gasket, before the pan is placed in position. It is important to place some sealant on the ends of this gasket and also on the oil pan gasket in this area."
Would you agree with this statement?
Should the side paper gaskets be placed so they come up next to the corks or under the corks?
Thanks.
Jamie
Thanks.
Jamie
