TR6 Cooling system filling
steveg
Are there any special techniques for filling the cooling system? The radiator cap looks to be lower than the thermostat housing.
The manual is unhelpful and AFAIK doesn't list the capacity. Moss says 13.2 pints (assume these are US not imperial).
charlie74
I think it is worth the effort to get the front of the car on stands or ramps, remove the thermostat and then fill with the heater valve open as well.
Tybalt
What charlie74 said, I use that method and it works reasonably well. You don't even need to bring the front end up all that high, just high enough that the radiator cap/filler is the highest point in the system. Then I cap up the radiator and install the thermostat and put some coolant in reservoir. Fire it up and let it come to temp and top up the reservoir if it pulls any coolant out of it when it gets up to temp.
As for capacity, it is listed on page 36 in the Bentley manual with an antifreeze mix table on page 58. Capacity is 11 Imperial pints, 13.2 wimpy undersized US pints or 6.4 L for the metricated folks. Since none of those correspond to exact conversions, my put is that those published capacities are all close enough to work but are all off by a little bit. In other words, they're close enough for an engineer but would drive a scientist mad.
Andy Blackley
I found the Lisle Spill Free Funnel to be very handy for filling the cooling system without the need for ramps etc: https://www.lislecorp.com/specialty-tools/spill-free-funnel-606
it comes with an adapter cap that fits on our radiators, and you fill the funnel well above the thermostat level, open the heater valve and run the car at idle until the thermostat opens and all of the air is expelled from the system. Turn the engine off and after it has cooled then remove the funnel with the yellow stopper and you are done. Pour the excess back into the antifreeze jug.
The downside is that it is a bit pricey for a funnel, but it does the job, and quickly too. There are several You-tube videos that show how you can make your own.
DarvinR
Great tips here. We'll be working on the TR6 after I finished installing the shocks and atv accessories on the TRX project. Got to find a good elevated space here to lift the car. Going to check the Bentley manual if that can help us a lot for the TR6 project.
steveg
steveg
Thanks to Andy above for showing the coolant funnel with stopper - I hadn't been aware of those. Bought one on Amazon (different brand) and used it. Worked like a charm! Just had the radiator serviced for a leak, also installing a 1/8" NPT bung in the top tank for the electric fan thermo switch and a 1/4" NPT bung in the bottom for a drain tap. I had run Thermocure for a couple of weeks to clear out the rust and am going to run this Tefba filter for a while to capture any loose rust bits.
When I removed the funnel, given the radiator cap is lower than the thermostat, not sure why no coolant overflowed the radiator.
Nice being able to fill the system without undoing the thermostat cover.
G Filling a completely dry cooling system.... Triumph 13
T TR2/3/3A Help - Cooling system problem Triumph 7
D Trying to understand my cooling system Austin Healey 29
HighAltitudeTR3 TR2/3/3A Cooling system normal? Triumph 11
7 stupid plastic cooling system parts Other Cars 2
mgedit TR2/3/3A Cooling System Flush Triumph 32
NutmegCT Cooling system clean/flush Restoration & Tools 11
steveg Cooling system filter installation - xpost Austin Healey 6
richie TR4/4A TR4a Cooling system temperatures Triumph 10
mgedit TR2/3/3A 56 TR3 Cooling System Triumph 2
T XKE Series 2 Cooling System Jaguar 0
RJS Cooling System Flush Triumph 3
QuickSilver Cooling System MG 11
hondo402000 TR6 flushing your cooling system, TR6 car specific Triumph 14
Moseso TR2/3/3A TR3 Cooling System Mystery Triumph 4
Dadandson Cylinder Head and Cross flow Cooling system Spridgets 12
KVH Air Pockets in Cooling System? Triumph 7
eschneider Favorite cooling system flush chemicals / brands? Restoration & Tools 3
martx-5 TR2/3/3A TR3 Cooling System Capacity Triumph 5
J oil in cooling system Austin Healey 11
T TR2/3/3A TR3 Cooling system Triumph 15
M Cooling system - thermostat Austin Healey 16
JPSmit Cooling System Question -1500 Midget Spridgets 3
S dish-washer soap in cooling system Triumph 11
Baz Heater box / cooling system Spridgets 8
John_Mc Cooling system flush question part 2 Triumph 3
John_Mc Cooling system flush question Triumph 1
S Wedge Oddities of the TR7 cooling system Triumph 1
sparkydave Darn cooling system! Spridgets 11
N Removing Cooling System Bubble Austin Healey 11
G Refilling the cooling system . Triumph 1
S Cooling System Question... MG 5
J Cooling System Austin Healey 15
J motor oil in cooling system-100/4 Austin Healey 4
Deanrobert Xke series lll cooling issues Jaguar 5
T TR2/3/3A Water pumps/head cooling Triumph 22
R For Sale TR6 COOLING FAN / ADAPTERS Triumph Classifieds 0
R Cooling Fan Color Austin Healey 6
Simmo General Tech Electric Cooling Fans. Are they a problem? Triumph 19
thibault 6 Blade cooling fan for 64 BJ8, advice? Austin Healey 25
D BT7 air ducting / cooling Austin Healey 20
brgrmyster GT6 Original GT6 Mk 1 cooling fan Triumph 24
F Cooling Austin Healey 3
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
R TR2/3/3A Non Triumph cooling question Triumph 8
apbos Parade Cooling Help Spridgets 12
Joe Reed MGB Removing stuck blade on factory electric cooling fan??? MG 7
D 2.4L internal cooling passages? Jaguar 4
J Another what cooling fan is this question? Austin Healey 47
H Denis Welch cooling fan arrived today Austin Healey 2
