George Zeck
I'm having some issues with my car cooling (or lack of). In short: Car has sat for 18 yrs unused. Have done many things to bring it "back to par" including: Thermostat / Thermostat housing (corosion caused it to leak), Flushed (forward & reverse) the radiator (what goes in appears to be coming out -- no blockage), flush engine block. Radiator fan works - although belt appears to be tight (it's a guess -- it does NOT make a squealling noise).
My gut tells me it's anti-freeze that has gelled inside of the block and preventing proper coolant flow. During by radiator / block flush -- I noticed "grainules" of green anti-freeze coming out. I must have not gotten all out because it stil heats up to boiling (212 degrees) in < 3 miles. Currently running 99% water & 1% coolant cleaner. Not sure if it's doing much (per directions).
I thought of a "radiator cleaner" -- but being that I can only go 3 miles at a time and they recommend driving the car for 3 - 6 hours (150 - 300 miles ??) -- not sure on what to do or how to approach the problem ???
I'm stumped on this one -- any help would be greatly appreciated.
/ubbthreads/images/graemlins/patriot.gif
