TNMGB
Okay, so I finally figured out that the reason my '79 B has been running hotter than usual is that I haven't been hearing the fans kick in. A mechanic buddy of mine took a look and after a short time under the hood decided it was the relay; we actually found the info in the owners' manual useful and jumped the switch on the top of the radiator and on came the fans. After turning off the ignition, I later tapped the relay while the engine was running and again the fans sprang to life.
Now here's the question: which relay do I use to replace this? I'm not seeing anything in Moss Motors that looks to be what I need so I don't know if something is interchangable here. Can someone offer a part number?
Also, I see that it is mounted by a screw to the fender well but when I turn the relay housing, the screw doesn't seem to be turning in the wheel well. Is there a trick to this that doens't seem to be obvious?
Thanks!
Thanks!
Hi Guest!
