Rick60
Hi all,
on a lately trip with my BT7 (outside temperature around 32 deg F) I noticed the temperature gauge not showing more than 120 deg F.
I was not too concerned about it cause I know the PO had disturbed the thread where the temperature sensor is screwed in. A new thread was made in the engine block, but not the correct size. He screwed in a small tube, about 2 inches long, with the correct thread on the other end, where he screwed in the temperature sensor.
I think at that point you all got it. The sensor isn't located directly in the stream of the hot coolant leaving the engine and is exposed to the air entering the engine bay. The colder the outside temperature, the less temperature is indicated. On hot summer days I can get an indication of about 160 - 180 deg F.
Does anybody know a solution for this problem? Is it difficult to "rethread" the original thread without taking the engine out?
Thanks as always for your thoughts.
Regards
Regards
