convertable top
bansheedave
Member
How does the header rail mount to the vinyl top on a 66 sprite with roll up windows and 2 piece remove able bow setup? I need a header rail and found one on ebay that the guy said came off a 67 midget and what looks like a fixed top. Moss shows they are all the same from 64-80 but doesn't show how they mount up. I don't want to purchase something that shows it fits but when I get it, i can't use it. If someone has pictures on how it is installed, that would be awesome.
SaxMan
Victoria British is consistent with Moss and indicates they will work. I've never used the 2 piece bow. I have the single frame in the '69 Sprite. I know my header rail mount was originally riveted to the convertible frame. Someone drilled out the rivets to replace the top and replaced them with sheet metal screws. The top goes on first and is glued on, then you put the header rail on. I replaced my top last year. I may have pics of the header rail mount.
Billm
There is a difference between the '64 thru '66 header bar and the '67 thru '79 but the ONLY difference is that the later ones have threaded holes in them to allow them to bolt onto the foldup frame. They will ALL ('64 thru '79) work for your early car
I don't have any pictures of the attach method but hopefully someone will
BillM
SaxMan
I searched my photos. I have a lot of the frame, but none of the header rail. Sorry that I can't be of help!
JPSmit
If you are asking how the top is attached to the rail - on mine ('76) it is glued on the top (contact cement) and, I think <think> the top then folds under and is further held in place by the retainer rail. The car isn't here for me to confirm that last bit - sorry
B
bansheedave
Member
So there isn't a connection between the header rail and the rear removable bows? It just pulls forward and latches to the windshield and that's it?
SaxMan
That's how it is on my '69.
I don't have the top with the removable bows, but my folding top just latches to the windshield.
nomad
Correct! You get a routine going pretty quick. Hook at back, over the still folded bow's, hook at front and attach all snap's and stud's, open bows. If you get caught in the rain you learn fast!
Kurt.
Joe Schlosser Convertable top bows Spridgets 3
C TR6 Convertable top mounting screws Triumph 5
M TR4/4A Convertable top mouting question? Triumph 1
P Breaking in a new convertable top Triumph 4
I Source for convertable top stowage bag? Spridgets 9
deadair TR2/3/3A TR3A -- Convertable top Triumph 18
S Convertable Top Fitment Issue Austin Healey 3
B convertable top fit Austin Healey 4
PAUL161 New Convertable Top For You Guys Up North! MG 6
S TR4/4A 63 TR4 clutch and convertable top questions Triumph 20
SCguy Wedge TR8 Convertable Top Triumph 13
AUSMHLY Convertable top Austin Healey 10
A TR4/4A TR4A convertable top mounting Triumph 6
S Convertable top part needed MG 2
jerrybny Convertable Top instructions Triumph 8
hondo402000 TR6 TR6 Convertable top installation Triumph 9
J CONVERTABLE TOP MG 11
A Convertable Top web straps Spridgets 4
S MGB Replacing convertable top on late model MGB MG 6
Steve P. TR4/4A TR4A: w/s to convertable top attach? Triumph 4
T Convertable on Tops on E-bay Spridgets 12
KLUTZ GT6 GT6 Convertable for sale up here ! Triumph 12
S SU H 1 carbs wanted for 1960 Herld convertable Triumph 8
M XJS 4.0 Convertable quarterlight sticking Jaguar 0
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
S TR6 Soft top material Triumph 10
Sarastro TR4/4A Convertible top installation problem Triumph 12
A TR6 TR 6 Soft Top Triumph 4
D BJ8 Top Installation Detail Austin Healey 3
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
zoohow BN4 Top Frame Installation Austin Healey 1
L Do you have a picture of these convertible top details? Spridgets 4
Popeye TR4/4A Attaching convertible top to bows - interior Triumph 2
Frameman 1949 Soft Top Webbing Austin Healey 2
Overdrive45 Convertible Top Cover Fit Austin Healey 6
D Top installer recommendations NYC tri-State area Austin Healey 0
69MGC T-Series Best Technique to Clean a Canvas Top MG 3
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
V For Sale Hard Top and Solid Walnut Dash for Sale Triumph Classifieds 2
T BJ7 Trim Recession (Convertible Top) Austin Healey 2
S For Sale FREE HARDTOP.. top is in Palm Springs, Cal. Call Bob ,562 400 5983 MG Classifieds 1
E Spitfire '69 Spitfire hard top Triumph 2
Celtic 77 MGB B-pillar repair kit for convertible top MG 1
Popeye TR4/4A Tonneau or top cover? Triumph 12
7 Top, hard Triumph 0
JPSmit Today's top tip - Rain X Restoration & Tools 3
Popeye General TR Old robbins top in box Triumph 7
KVH TR4/4A Closing the Soft Top Triumph 11
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
