Steve Huneck
Hi,
I have just removed my horn quadrant/control head from my BJ7 and have found some issues that require attention. I thought I would solicit some opinions on the best way to proceed.
Here is what I have;
A two piece stator tube, the bottom piece has a slot, but the top piece seems to have just been pounded into the bottom piece.
I do not have a nut on the steering wheel end just a circlip, but I do have the large plastic clamping nut.
I have the olive at the bottom end which held the stator tube in place.
I only have one wire, for one horn, running down the tube.
I am missing the trafficator lever (I have a switch on the dash for the turn signals), and a quick peek looks like I am missing the pawls and springs.
So, I would like to replace the whole control head, but can I go with the adjustable version? It is quite a bit cheaper than the non-adjustable.
Any thoughts/opinions/experiences are very appreciated.
Thanks,
Steve
Thanks,
Steve
Hi Guest!
] cut the original stator tube off below the Horn assembly and then forced it on to an adjustable stator tube where the slot in the adjustable tube allowed the mating..---Fwiw--Keoke
