Go_Dogs_Go
When I bought my electronic ignition distributer my Sprite was Pos ground and now I want to install an alternator. Has anyone converted the Pertronix Flame-Thrower to negative ground from positive ground? I see a Pertronix igniter kit for sale that is used to convert points to electronic and it looks like the part installed in the distributor. Would that work if I used a Pertronics neg-ground ignitor part in my pos ground Pertronix? Or is the exisiting module in the Pertronix distributor a different part altogether?
Simpler solution maybe: could I simply drop a new plate, points, condensor into the Pertronix distributor and do the standard method of converting the car to negative ground?
I really appreciate your help.
GDG
GDG
Hi Guest!
