Las Sunday we had made a new attempt to free the clutch by towing the car. In 4 th and 3 rd gear. Unfortunately the clutch is still not working, so it seems, that this isn’t up to now the way to success.
Initially the clutch pedal had no pressure at ( most likely due to air pockets ) when we finally had the air out we had a decent pressure on the clutch pedal but the clutch is still not operating the way it should be .
When using the clutch pedal the pushrod in the slave cylinder push the lever 13 mm ( 13, millimeter, = 0.511811 inch ) and wonder, if this is enough. What can all still be wrong with the clutch?
More and more I got the feeling, that the clutch need te be taken apart completely, if so is there advice how to do this in the best possible way. I will open a new thread with this question, so it will be easy to search for other forum members
Hi Guest!
