Our house is almost 80 years old. When it was built it was built with a separate garage. about 10 years later they built an apartment over the garage and closed in the space between house and garage. So, if you can imagine it, at the front of the house on the left - in that space - there is now an interior staircase up to the apartment. At the back of the house "under" the staircase is the rest of that closed in space. It is about 4' X 10' and is kind of a mud room - three doors, 1 to outside, 1 to garage, 1 into the house.
I am currently refinishing this space to make it more a part of the house. It will still only be a mudroom but will be finished and tiled properly with likely a bar fridge and wine cooler.
Initially I planned to put a small electric heater in there for winter but, SWMBO would prefer we run ducting into the space. Not impossible as it turns out. However, for a space that small do I need a cold air return?
I can do it reasonable easily but would rather not have to.
Thoughts?
Thoughts?
