TR5/TR250 Compression #
tinman58
We now have about 650 moiled on the 250. We just drove to the Tibuorn show on Saturday. 160 miles round trip. The motor runs smooth but I feel that there is excess oil consumption. A good 1/2 quart in that 160 miles. I have 1 small oil leak at the front timing chain cover. (the size of a quarter). The plugs are a little black, running a little rich.
I checked the compression on each cylinder and came up with these numbers.
1- 137
2- 142
3- 140
4- 144
5- 145
6- 145
The motor is a 1972 model TR6. The compression was raised to 9.5 to 1, I don't know if these numbers are low, high or what. I can't find anything on the compression lbs. How long will it take for the oil rings to seat? Or am I just being a little pearinoid?
Geo Hahn
...How long will it take for the oil rings to seat? Or am I just being a little pearinoid?
Possibly -- what break-in procedure did you follow?
Unless shockingly low I usually regard the usefulness of compression numbers to be comparative from one cylinder to the others rather a meaningful absolute value. For one thing, some gauges are not particularly accurate (though they usually yield repeatable results).
poolboy
Once you go thru the compression test with 'dry' cylinders, then right away do it again adding 2 tablespoon equivalents of motor oil to each cylinder as you get to it you'll get an idea about the rings sealing.
glemon
Dan on my rebuild I got about 160-165 in each, also going to a 9.5/1 ratio with a milled head. That said as noted the gauge might be off.
tinman58
tinman58
I did the 20 minute break in for the cam and lifters. I also used break in oil for the first 500 miles. Changed the oil and used valvoline 20-50 oil in it now. During the first 500 miles I just drove it normally, but never got close to red line 3800 rpm's max. I did not baby it but did not abuse it at all.
Geo Hahn
...During the first 500 miles I just drove it normally, but never got close to red line 3800 rpm's max. I did not baby it but did not abuse it at all.
I prefer to break-in new rings with something closer to abuse... hard acceleration followed by abrupt deceleration. Rinse, repeat.
I try to avoid driving at a steady RPM (like one might normally drive). You do not want to lug the engine at low RPMs, but IMO high RPMs and abrupt change are needed to seat the rings.
I once had an engine that the PO had replaced the rings and, I suspect, never got them to seat. The procedure described above didn't help and in the end I did the thing with a dose of Bon Ami in the intake. It isn't an abrasive but rather absorbs the oil from the cylinder walls so you get a couple of dry strokes before lubrication resumes. That seemed to do the trick.
JerryVV
Are you using oil with ZDDP? Valvoline 20-50 may not have enough for your flat tappet lifters and cam. You'll wipe it out quickly without added ZDDP of oil such as Brad Penn which has the required levels of ZDDP.
Jerry
A really bad thought. We rebuilt 3 engines, all with parts from a major supplier. Two of the engines had oil rings that were 3 parts. Top and bottom scraper, and a tension ring in between. The tension rings broke the ends off on two of the engines and they ate some much oil (pushed up the cylinder walls) that we had to pull the pistons out the bottom and replaced the oil rings. That cured the problem. The third engine had parts from the same supplier but the oil rings were different. No problems burning oil with that engine.
Our replacement rings were from Hastings. You can look the rings up on their web site and see if yours look like that.
Jerry
tinman58
tinman58
I have added the zddp with the break in and with the valovline. Jerry I got the pistons and rings from british parts northwest. I think. I will just keep driving. Recheck compression in another 500 miles.
TR3driver
Great Pumpkin - R.I.P
Just want to point out: There are two different Bon Ami powders and one of them does have the hard abrasives in it that can scratch cylinder walls and so on. If you are going to do this, be sure to hunt for the one that says it is safe to use on glass.
When I went looking, none of the local grocery stores had the "safe for glass" variety; but I found it at OSH.
Running rich can be really bad on new rings, especially if you are running fuel with ethanol added.
Based on my own (limited) experience, I'd say a pint in 160 miles cannot be adequately explained by rings that have not "seated". They should do better than that even right out of the box! One experiment I would try first is to have someone follow you, and look to see whether the blue smoke is worse when you get on the throttle; or if you get a big puff of blue when shifting. The latter indicates oil getting past the intake guides rather than the rings.
After that, I'd be pulling a piston to see WTF.
PS, Here's a write-up on the two different versions of Bon Ami. Apparently, they have changed the labels yet again.
https://www.bonami.com/index.php/products/powder_cleanser/
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
petnatcar Compression Test Record Form Austin Healey 0
W Cylinder compression Hillman super minx Other British Cars 15
Donald1107 TR2/3/3A low cylinder compression Triumph 12
kodpkd Compression Test Results Austin Healey 1
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
Martinld123 Compression check 1956 BN2 Austin Healey 7
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
T Milling a head on a Stock 1275 for compression? Spridgets 13
RichBall For us 1500 guys, high compression head up on Ebay Spridgets 10
M TR4/4A TR4 Optimal Compression - 91 Octane Pump Gas Triumph 13
pkmh Compression Test Results for BJ8 Austin Healey 14
TulsaFred 1275 compression ratios and horsepower Spridgets 29
R TR4/4A TR4a engine compression Triumph 6
