<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by ThomP:
I'm facinated by the fact that a healthy Healey has compression readings around 165 lbs. If that is taken at face value; that means the compression ratio is 165/14.7 ~ 11.2:1 This is much higher than the published numbers. That air must get really warm when you "squish" it.
<hr></blockquote>
Thom,
Your calculation is correct for "isothermal" compression which assumes that no heat is gained or lost during the compression cycle & if the actual compression ratio were the same as the rated ratio. - See below. The formula for "adiabatic" compression takes heat loss or gain into consideration. Eg. as the air is compressed it is heated by the compression & the final pressure is higher than would be predicted by isothermal compression. The variables are rather large & the difference between the two calculations can vary by a large factor in the final pressure. The pressure rise due to heating is an expotential function. (more heat = more pressure = more heat = more pressure). The exponent will vary from one with complete heat loss to about 1.4 with no heat loss.
Rated vs actual compression ratio ---------
To complicate things , at low rpm such as cranking speeds --
The actual engine compression ratio is never the design calculated ratio because in reality the piston cannot begin to compress anything until the intake valve gets closed. If the intake valve were to be completely closed at BDC, which by design it never is, the actual & rated compression ratios would be the same. At higher rpms & thus higher intake gas velocities, the late closing of the intake valve is offset by the gas inertia in the intake tract & the engine can approach or exceed it's design compression ratio.
For a hypothetical engine with a rated 9/1 compression ratio, Assume that the actual mechanical CR is 6/1 due to late intake valve closing. We can calculate that the pressure for isothermal compression would be 14.7 * 6 = 88 psi. With an adiabatic exponent of 1.14 this would give a compression pressure of 165 psi.
Whether heat is gained or lost during compression depends on several things such as how quickly the compression takes place (starter & engine cranking speed), temperature of the engine during the test (is the air in the cylinder hotter or cooler than the air compressed in it) , & a few other variables. The end result is usually that the measured compression pressure is a bit higher than would be calculated by isothermal compression.
The compression pressures given at "face value" are empirically determined from measurments & experience. There are just to many variables to make accurate calculations.
