Deleted member 8987
Yeah, cap.
Exhaust pipe is an exhaust valve issue, through the carb, butterfly open, is intakes, oil fill cap, rings (or piston).
Compression tests are dynamic, meaning they are reading what your engine is doing while rotating.
It will show issues leakdowns will not (like, a cylinder that is very wide in the centre of the bore), and a leakdown is static, which means you are looking for issues with the engine at rest.
Sometimes, if you have a completely shot guide, and air pressure from a leakdown happens to seat the valve, you won't see it, but on a cranking compression test, you will.
To simply say one type of test and not the other is ludicrous.
I do a comp test FIORST, then do a leakdown if it warrants.
That said, VW air cooled seem to prefer leakdowns first.
