Morris said:
Would a different cam profile have any effect on what CR I can safely run pump gas. I have read a few confusing posts on other forums where posters claim that a longer cam duration or a later opening intake valve will have a positive effect on your engines ability to run high CR on low octane.
What we are discussing here is static compression ratio, and yes dynamic compressed ratio can be lowered somewhat with higher lift and longer duration cam, but at the end of the day gains are still gotten using a higher lift and duration cam.
Alot of things in performance engine building ends up being compromises, for example when you use a higher lift cam you ask the rocker arm to go down further in it's arc, which lower the rocker arm ratio, but at the end of the day a gain is stil made.
Ironicly enough we did a R&D test yesterday on a SCCA limited prep 1275 race engine, on those engines we have to use stock rocker arms. What we did was make a plate the is held on the side of the head by the 5 head studs on the spark plug side of the head, so I could we could torque everything down like it would normally be, and using magnetic base and dial indicator, go one by one to each valve retainer and measure actual operating valve lift, this would tell us a couple of things, were we under the max allowed .450" ( SCCA rules for this engine)and what was our rocker arm ratio, and did the stock rocker arms vary much in ratio. Well my first 4 I check were within a couple of thousands, but few of them at the other end varied a bit, we had a low .414" lift and high of .435", the .435" is where we would like all of them to be, because SCCA check max valve lift with zero valve lash, so with .015" valve lash, that was perfect. Now in the end we maybe could play with swapping other rocker arms on for the couple that resd a little low, but these heads don't gain much flow at maximum valve lift, so it would probably make little to no difference.
Now I have not had time to sit and do the math yet, but we're using one of Mike's Comptune race cams and I know first hand the advertised lobe lifts are all within a thousands or two (this is the norm on most cams), so any valve lift varience we get is in the rocker arms. If the valve lift number were real low, we could have palyed with custom lnegth pushord or rocker arm pedestal shims, but being our findings are what they are we are close enough.
I know all this is getting a bit gear-heady, but Mike and I have a habit of doing such things we you get us started
