Compression check 1956 BN2
Martinld123
Bronze
I had the engine rebuilt about a year ago but have been having some problems with rough running. The engine has 100M larger size pistons. So I did a compression check. No too long after the engine was broken-in the compression was 1 - 4, 183, 185, 184, 183. A year later with 5,000 miles or so on the engine the compression was 1-4, 165, 170, 180, and 170. Then I put some oil in each cylinder to test it again then it was, 1-4, 172, 176, 186, and 176. What does this tell you?? From what I have read it seems like the numbers are too far apart? Thanks Marty
Oil in the cylinders helps rings seal a bit better, so you have some leakage around the rings, which is normal. I'm not sure what you mean by '100M larger size pistons;' the M pistons were differentiated by having a shallower dish on top (if your cylinders were bored the pistons would be larger in diameter). Anyway, compression readings can vary some based on technique, battery condition, phase of the moon, etc. Yours are not far off--10% difference is acceptable--and not likely the cause of your rough running; I'd start with the ignition.
My BJ8 has accross-the-board lower readings, with a larger variance than yours, but runs like the proverbial 'Swiss watch.'
Martinld123
Martinld123
Bronze
Thanks, your info makes me feel better about engine. Okay, I checked wires with ohm meter plus checked out in dark with all good. Distributor is original so maybe I will send it out to have it rebuilt. Thanks for help, Marty
I'd try new points and condensor first (if you can find decent quality). If you have a dwell meter check that, if dwell 'wobbles around' a bit you might need a rebuild, otherwise you shouldn't. Check timing, spark at the plugs, etc. You said car 'runs rough,' but is it rough idle, stumbling, or ?
Martinld123
Martinld123
Bronze
Bob, I have been using a Pertronix ignitor in original distributor with good luck until now. It does wobble some but I thought that would be less of a problem with Pertronix. I had someone look at it last year and he seemed to think it was okay. Timing has always been a problem for me with no timing marks on engine so I set it until engine pings then back off. Not the best I know but worked well in past. When driving at times it feels like it is running out of petrol. Need to think back. We just got back from Florida so being away for 6 weeks has not helped my memory, lol. I will have to get my thoughts together and report back, Marty
CraigC
Martin, there are timing marks on your engine. Look closely and you will see an arrow stamped into the timing cover directly above crank pulley. On the original crank pulley you should find a 1/16" hole drilled near the edge on the rear half of pulley. It lines up with the arrow when you are at TDC cylinder #1. Use a "dial-back" type timing light to check/set timing.
busybrit
When you say it runs rough is this on Idle? or when you actually drive the car. What happens when you pull the choke out a little once the engine has warmed up? With the air filters off, looking at the pistons on the carbs, do they lift at the same rate? Does one vibrate more than the other?
I'm testing for a vacuum leak !
Johnb
Martinld123
Martinld123
Bronze
Thanks for responding. Out of town and just got back. I bought brand new SU carbs from Moss that are sitting on my work bench now. But I did check the lift of of pistons on old carbs and they did match. Vibration in either was not on my watch list at that time but used system that had let me see piston movement and all looked good, solid, and equal. I sent out my distributor to Advanced Distributor, Shakopee, MN, for a rebuild so hope I am covering all of my bases. Going to have a fresh start. Thanks Marty
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
lbc_newbie compression check on uninstalled engine? How? Spridgets 2
wkilleffer Curious about compression check results MG 5
wkilleffer Latest compression check numbers MG 6
2wrench Compression check question for '72 Triumph Triumph 1
prb51 Compression check Triumph 14
RocknTommy compression check on a 1500 Spridgets 3
petnatcar Compression Test Record Form Austin Healey 0
W Cylinder compression Hillman super minx Other British Cars 15
Donald1107 TR2/3/3A low cylinder compression Triumph 12
kodpkd Compression Test Results Austin Healey 1
Patrick67BJ8 Cylinder Compression Checks Austin Healey 30
B TR4/4A Finding compression stroke Triumph 7
M TR6 High Compression in One Cylinder Triumph 28
AUSMHLY Compression test results Austin Healey 17
S TR2/3/3A Compression Triumph 8
J TR2/3/3A Figure of Eight Gasket Compression - Copper vs. Steel Triumph 18
NutmegCT Variable compression? Other Cars 22
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
edkap2002 TR6 fuel line compression fittings....how to remove Triumph 3
R TR2/3/3A Good Compression Triumph 1
3798j Fastronix Battery Compression Ends Restoration & Tools 4
F TR2/3/3A Compression Test Triumph 13
K TR2/3/3A Compression testing again... Triumph 4
HighAltitudeTR3 TR2/3/3A Compression Question Triumph 10
warwick-steve High compression head identification Austin Healey 16
Tinkerman TR2/3/3A 1960 TR3A engine compression question. Triumph 7
Jim_Gruber Bugsy IV and Engine Compression :[ Spridgets 11
2 TR2/3/3A compression numbers Triumph 1
P TR6 Latest compression test Triumph 11
MY66AH Compression woes Spridgets 11
S Unexpected Compression Readings Austin Healey 14
Gliderman8 TR6 Compression help in one cylinder Triumph 7
tinman58 TR2/3/3A Surprise on compression. Triumph 9
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
T TR6 TR6 compression test Triumph 12
B TR6 Fuel tank to line compression fitting Triumph 1
tinman58 TR5/TR250 Compression # Triumph 9
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
M Compression test results Austin Healey 11
R TR2/3/3A Steering, stator tube compression sleeve? Triumph 4
Kleykamp TR2/3/3A compression numbers & smoking engine Triumph 20
S Bugeye 948cc Compression Spridgets 7
L 1275 Compression, Camshaft, et al Spridgets 16
me61ic Compression results - Worth Rebuiding? Austin Healey 13
D Compression #'s Triumph 13
Tinkerman TR2/3/3A 60 TR3A Compression test Triumph 15
D Austin Healey 100-6 Compression Austin Healey 1
P TR6 1971 TR6 compression Triumph 2
T TR6 TR6 fuel line / mechanical fuel pump compression? Triumph 5
