I am going to come clean, not even my wife knows all these details.
I have been doing some maintenance and upgrades on the 6.
I have replaced all the u-joints, balanced the drive line.
New TRF clutch, and a Quantumechanics trans and J overdrive.
That's why the earlier question about the grease for the sliding axles.
What is the wiring diagram for this overdrive, my manual shows what I understand to be a earlier version using a overdrive relay. I understand my '74 does not use a relay, is this correct?
I am installing a new clutch slave cylinder and SS braided line.
I am replacing the thrust washer as it has about 10 thou wear. This should get rid of the clutch shudder, it has had since I bought it.
I had the distrubtor rebuilt and recurved as it was missing the advance spring.
I also got one of the PVC gearbox tunnels. This brings about another question. The holes are not fully drilled on the cover where it would bolt to the fire wall, has anyone fit one of these before. Should I just drill out the holes or fit it up and drill where they fall out at. A quick test fit seems to show that some of the holes along the side would be better elongated, so I am leary of just drilling the other holes out, unless someone else has and it worked.
Thanks
Thanks
