TR4/4A Cold Weather TR4 Starting--Metallic Sound
KVH
I guess it's normal in cold weather to hear the ring gear and starter pinion roughly engage with a discomforting metallic ping sound on ignition spark?
I only say that because the sound seems rather familiar to what I heard years ago in my other TR4--in the cold winters.
thx
DougF
Maybe the grease is a little cold/hard and slowing things down a little.
Geo Hahn
Kentvillehound said:
...I guess it's normal in cold weather...
Cold weather -- you must be referring to that morning when it got down to 45 degrees here in Tucson?
Actually, my TR4 engages with a fairly abrupt metallic sound. Considering what it going on -- the mating of two metal parts without the benefit of any lube -- it is pretty much the sound I would expect to hear.
Having had several recent opportunities to see the flywheel, I do not think anything untoward is going on with mine.
Next time we're together we'll compare starter noises.
R Very Difficult cold weather starting problems! Austin Healey 21
theleisure Cold Weather, Oil Pressure Spridgets 10
S Jag barely runs in cold weather Jaguar 7
RickB Cold weather and oil viscosity? Spridgets 8
kodanja Cold weather Effecting Performance? +- Triumph 35
MadRiver Cold weather starting Austin Healey 12
BoneIdle cold weather starting woes MG 5
1 Cold weather stalling MG 15
drooartz Squealing brakes at startup in cold weather Other Cars 2
wkilleffer Cold weather engine tuning MG 30
jlaird For our cold weather friends Spridgets 6
nevets starting ether and cold weather starting Austin Healey 53
S Cold Weather Starting Austin Healey 6
Rick60 Coolant temperature in cold weather Austin Healey 10
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
RAC68 Cold Air Bilge Blower update Austin Healey 13
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
Morris Cold Air Intake Spridgets 2
S Cold galvanizing zinc spray Restoration & Tools 5
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
D cold air duct 100 Austin Healey 3
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
