TR4/4A Cold Weather TR4 Starting--Metallic Sound
KVH
I guess it's normal in cold weather to hear the ring gear and starter pinion roughly engage with a discomforting metallic ping sound on ignition spark?
I only say that because the sound seems rather familiar to what I heard years ago in my other TR4--in the cold winters.
thx
Maybe the grease is a little cold/hard and slowing things down a little.
Kentvillehound said:
...I guess it's normal in cold weather...
Cold weather -- you must be referring to that morning when it got down to 45 degrees here in Tucson?
Actually, my TR4 engages with a fairly abrupt metallic sound. Considering what it going on -- the mating of two metal parts without the benefit of any lube -- it is pretty much the sound I would expect to hear.
Having had several recent opportunities to see the flywheel, I do not think anything untoward is going on with mine.
Next time we're together we'll compare starter noises.
