wkilleffer
Maybe this wasn't the greatest idea, but I went ahead and tore into it under the assumption that the gaskets could need replacement due to their age. The running spray test just didn't seem to tell me much one way or the other.
Well, one snapped stud and ruined exhaust/intake manifold gasket later, it's true.
In addition, the heat shield has almost no shielding material left on it. What little is there, is probably not doing much good. Looks like asbestos. Yay...
How do I get the steering stuff out of the way where I can move the exhaust enough to put the new gasket in?
Hopefully, Tony will be able to supply a good used heat shield, new gaskets, and a new stud to replace the snapped one.
Thank you,
Thank you,
