Maybe not. A new neighbor gal asked me to look at the brakes on her Bugeye Sprite. She said when she starts out early in the day the brakes act fine, but very quickly the pedal gets hard and the braking is very poor. I suspected something causing the brakes to not release and sure enough when she pulled into my shop the wheels were very tight. i spent some time cleaning and deglasing the brake shoes and drums. Assured myself the wheel cylinders were working at all corners and that there was no leaks. I put things back together and adjusted the brakes fairly loosely and was hopeful that I had solved the problem. All the wheels turned freely. But after only a few applications of the brake pedal ALL wheels got somewhat tight. The wheel cylinders look like they are fairly new and the the hoses, (one back, two front) don't look that old either. Should I immediately suspect the Master Cylinder. It seems with only a few applications of the brake pedal, the brakes on all the wheels don't want to completely release. Yet let it set a few hours and the wheels are free again. Thanks for the help.
