Coils and ballast resistors
john_j
May car, which isn't a P6 2200, has, because I put one in, a P6 2200 engine.
Now, it has a coil with no label, so I don't know what voltage it is, I will check the resistance to see if that helps, [edit - it's 1.7 ohms]I think the choice is to chuck this coil and buy a 12v one, but I don't know what spec to ask for - it's no good asking for a P6 2200, cos I will get a 7v one, so does anyone have a spec, or a model that has a suitable 12v one?
Alternatively I could get a ballast resistor, but I don't know the spec for that either, and if I can't identify the coil it probably doesn't help much.
[Edit] I decided that the easiest solution was to chuck the coil and buy another one, so you can ignore the question now!
Any suggestions?
dklawson
Land Rovers aren't something I have worked on but I noticed your thread title when the forum list page opened up.
If you're looking for a good 12V coil, one that is readily available and reliable, consider the Bosch Blue Coil. This is a very good, standard 12V coil that's been used for decades. Over the years it's been one of the common replacements for Lucas coils.
rovernut
The Rover 2000 and 2200 use a 12v coil.... with no ballast resistor........although later models may have used the ballast resistor......i can send you an original coil for the 2200 if you need one
Bill Robertson
S TR2/3/3A On those old original coils Triumph 2
CJD TR2/3/3A Screw Post Coils Triumph 6
S TR2/3/3A tr3 coils Triumph 19
7 Ignition coils Triumph 22
M New coils for old Triumph 11
hondo402000 suggestions on Ignition coils Triumph 22
AEW Which Lucas coils have PCB oil in them? Triumph 8
F My car is eating coils Austin Healey 22
P Coils and weak spark? Spridgets 1
jhorton3 Coils Gone Bad Spridgets 5
E sport coils Triumph 9
T Why do coils die? Triumph 42
bmurphy7369 Bosch Blue Coils... for older OPUS systems? Jaguar 3
B Lucas coils Austin Healey 9
tony barnhill NORTON BOYER ELECTRONIC IGNITION WITH COILS &podtr British Motorbikes 4
S Petronix coils... MG 1
Bret Timing Lights & Hot Coils question Restoration & Tools 3
Jim_Stevens TR2/3/3A Ballast resistor to prevent hyperflashing Triumph 5
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Marla TR4/4A Ballast or Non... Triumph 6
2wrench TR6 1974 TR6: Ballast vs Non-ballast system. A look at the wiring. Triumph 58
NutmegCT ballast resistor Other Cars 10
A Ballast resistor Triumph 7
SilentUnicorn MGB ballast wire mgb 77 MG 2
TulsaFred Ballast resistor Spridgets 28
regularman Ballast resistor mystery Spridgets 2
T External ballast resistors - do they go bad? Triumph 8
A ballast resistor 75 mgb FORUM Navigation Questions 0
A MGB ballast resistor 75 mgb MG 2
H Ballast resistor MG 9
RynoBoy74tr6 Ballast resistor location.... Triumph 10
newmexTR3 TR2/3/3A Pertronix on TR3 Ballast Resistor or no? Triumph 3
8 BALLAST RESISTOR???? Triumph 12
T Wedge Cut wire on TR8 Ballast Resister Triumph 2
J Spitfire Spitfire Ballast Resistor Triumph 3
C Ballast Resistor Spridgets 34
B TR6 TR6 / Pertronix / Ballast Resistor / etc Triumph 13
RichC Primary Ballast Resistor Ignition? MG 1
R Link to Ballast resistor wireing Jaguar 0
