While fiddling in the engine with a carburetor problem, I touched the coil - and nearly burnt my arm! The coil was so hot I could not hold it for more than 2 seconds. I assume this is not normal. I know they get warm, but should not cook. Apart from a faulty coil, could anything else be causing this issue?
Distributor is a Lucas 25D with Lumenition electronic module and the Lumenition coil spec'ed for this setup.
Any advice appreciated.
Thanks!
Thanks!
