Finally some warm weather here in eastern NC. I started working on the '51 TD I bought last fall. I am checking the wiring and noticed the PO had disconnected the coil wires. I could not find the correct polarity information in the wiring diagram, or I don't know how to read it properly. Which side of the coil does the wire coming from the distributor go to, the + or - side? The TD is still set up as positive ground.
Thanks,
Charlie
Thanks,
Charlie
