CuriousGeorge
I read somewhere that you must run the negative wire from the coil to the distributor, NOT the positive or you will shorten the life of the points. Anyone know if this is correct?
TR3driver said:...What happens is that it's easier for the spark to jump the plug gap in one direction...
TR3driver said:What happens is that it's easier for the spark to jump the plug gap in one direction...
Nope, plug gap. Ideally it doesn't jump the point gap at all (which is the main function of the condenser).Geo Hahn said:Did you mean 'points gap'?
prb51 said:If you want points to last until the spring wears out (10-12K) use an MSD6 unit. No pitting, no dwell issues, not gap sensitive.
However, on a TR2-4, the spark from the MSD will toast the center conductor in the distributor cap! BTDT; used a paper clip to get home :banana:
