Coil terminals
Following my usual pattern of over complicating things, am I correct that coming out of the harness, the white wires goes to the positive terminal on the flamethrower coil, and the black and white to the negative. The car has been converted to negative ground. Then the second pair of white and white and black go to the dizzy. Right?
Thanks, as usual🙂
Eager to hear replies to your question.
I have a harness that has the w and w/b connected together on an round terminal connector.
I’m using a Petronix type distributor that has two wires coming out one black one red.
I’m guessing the two sets connect together somehow?
