T
Tinster
So I replaced the rocker arm shaft, adjusted the valves and the car
started with difficulty. Ran for 15 to 20 minutes on full choke.
Shut down to cool over night.
Adjusted valves for second time, not much difference.
Car started with great difficulty and would hold idle at
1000 RPM with full choke on. Reset timing to 10* advance.
Engine ran very rough- I replaced almost broken rotor.
Next day car would not start at all-very weak spark at No1.
Charged battery overnight.
Next morning car would not start.
I could not pick up a spark from any plug wire or coil lead.
I installed all new plug wires and coil wires- car would not start
Then I installed all new .025 gap plugs-car would not start.
Then I installed new dizzy cap- car would not start.
Then I installed yet another new rotor- car would not start
Then I installed a new dizzy condenser can- car would not start.
Cleaned the points-car would not start.
I noticed I had not properly tightened down the dizzy.
From memory I tried various positions of the dizzy- car would not start.
Static timed the dizzy and let battery charge overnight.
This morning no spark from coil to dizzy. I replaced coil- car does not start.
The engine spins strongly and sounds like it wants to fire up but doesn't.
Spark from new coil to dizzy appears very weak and twitchy..
Once again please. How do I ohm test the coil to see if the coil is my problem.
Plenty of fuel-so I'm at a loss what to try next.
Thanks once again. All this from replacing the rocker arm shaft. YeeGads!!
