CNC Machine Info needed
DNK
Does anyone have use of a CNC machine to make a small bracket?
I guess that is what the machine is called
Re: CNC Machine work needed
What do you need made?
do you have a sketch?
m
any decent sheet metal shop could make those. water jet and bend, or punch and bend. How many do you need? left and right? or both same
m
I could do it if you can supply a scale drawing, either paper, or CAD. I sometimes run the waterjet at work.
:iagree: Drillmotor, drill bit, saw, grinder and or files, vice, hammer, sandpaper, paint.... Beer. :thirsty:
So here's the reason on the question.
Need a bracket for a MAP sensor so I do the Google thing and I find all of them $30 or more. I find this a little incredible. I see this and he want $60 for it???
I just cant imagine it cost that much
I've had some custom parts made on a waterjet. The minimum charge is $150. I could probably find a cheaper source, but that gives you a ballpark figure. Last thing I had made were concentric circles from 1" thick aluminum. Not something a sabersaw would have done very well. :wink:
kellysguy said:
Whatcha putting a MAP sensor on?
Tryin' to fix a broken GPS...... :jester:
Try emachineshop.com
www.emachineshop.com
Last time I checked, they didnt have a minimum setup charge.
Don
Try Tacoma Steel (obviously in Tacoma).
They are very reasonable and local!!!
BillM
OhhhhYeah!!! :iagree:
It's that or pay the $60 and just drink th' beer. :jester:
