BruceAllcorn
I have a '62 Healey and the clutch is just releasing enough to be able to shift gears, although it sometimes grinds a little, especially going into reverse. I know there is no trapped air in the fluid lines or in the slave or master cylinders, and both are working correctly. I suspect the problem is inside the clutch housing because when I disconnect the slave cylinder push rod the clutch fork has a lot of play in it. Looking for a heads up, I was wondering if anyone has ever experienced this and what they found. This will be my first time pulling a transmission and replacing a clutch, and looking at the diagram I'm wondering if the release bearing retainers (one or both) maybe have "come off" causing the release bearing to only partially "engage". Whoever put the last clutch in made a slave cylinder push rod that is approximately 3/4" longer that the standard rod to get the clutch to release, which it barely does. Any thoughts would be appreciated.
Regards,
Bruce
Regards,
Bruce
Hi Guest!
