Shane
Howdy all...
I went to start our 1962 BT7 up to take Holly to see the gorgeous Missouri/Illinois fall leaves and the clutch dropped straight to the floor. I checked the brake/clutch fluid reservoir and the center cylinder was empty. I added fresh fluid, pumped the pedal around 30 times and never got any resistance. The fluid in the reservoir never moved, either.
I then crawled underneath by the pedals and pushed the pedal down again and heard a little slurping noise, and noticed some dried up fluid around the rubber seal. I then checked under the hood and noticed the same dried up fluid where it leaked from the master cylinder.
I noticed a repair kit offered by Moss and I was wondering if anyone has used one of these to replace their seals. I also noticed a similiar repair kit for the slave cylinder and was thinking replacing those seals as well. I didn't notice any leakage around it, maybe if it ain't broke, don't fix it?
Any suggestions would be appreciated...
shane
[ 11-09-2002: Message edited by: Holly and Shane ]
[ 11-09-2002: Message edited by: Holly and Shane ]</p>
shane
